Tables that you have created with a common dataset initially contain all columns and rows that can also be found in the table view of the common dataset. Of course, you also have the option of adding new columns to these tables and filling them with your own data. The advantage: data in columns that are not linked to the common dataset are not overwritten during synchronization .
This function makes it possible, for example, for common datasets to be used by multiple departments and employee groups within a company in a wide variety of contexts.
Adding columns works the same way as with usual tables. You can find detailed click instructions here .
Add columns to a table created with a common dataset
Care must be taken when editing columns of a common dataset. If you make changes in columns containing data of a common dataset, these changes will be overwritten again during the next synchronization of the data set and will thus be lost.
To ensure an optimal workflow and to avoid both data loss and misunderstandings during collaboration, it is recommended to lock all columns containing data of a common dataset for editing. On the other hand, you can edit the individually added additional columns as you wish.
Locking columns of the common dataset
  1. Click the triangle icon of a column you want to lock for editing.
  2. Click column permissions edit.
  3. Select for whom you want to restrict the editing of the cells.
  4. For single and multiple selection columns, you can additionally restrict the creation of options.
You can restrict editing for each column individually, so you can always decide whether it can be edited only by administrators, by certain users or by no one at all.
Locking the column basically prevents the cells from being edited. For certain column types, such as single or multiple selection, it is also possible to restrict the creation of options.
Column of a common dataset locked for editing (left) and editable column newly added to a common dataset (right).
