Imagine that you always want to activate a checkbox in exactly one row in a base. When this checkbox is activated, all other checkboxes that may be filled should be deactivated. You can easily perform this operation with a script, e.g. via a button.
The result
Each time you click on the button, the checkbox in this row will be activated and all others will be deactivated.
The complete script
// vars
const viewName = 'Default View';
const targetCheckboxColumnName = 'Checkbox';
// code - don't change careless!
const currentRow = base.context.currentRow;
const table = base.getActiveTable();
const view = base.getViewByName(table, viewName);
const rows = base.getRows(table, view);
const selectedRows = [],
updatedRows = [];
// set check
base.modifyRow(table, currentRow, { [targetCheckboxColumnName]: true });
// remove all other checks
let pos = 0;
rows.forEach((row) => {
if (pos >= 0 && row[targetCheckboxColumnName]) {
selectedRows.push(row);
updatedRows.push({ [targetCheckboxColumnName]: false });
pos++;
base.modifyRows(table, selectedRows, updatedRows);
