Owners and administrators of a group can add members, remove members, and change permissions of existing group members. In this article, you will learn the two ways to add team members to a group.
  1. Go to the home page of SeaTable.
  2. Click the triangle icon to the right of the group name.
  3. Select the Manage members option.
Manage members
  1. Enter the name in the search field.
  2. Confirm with Submit.
Search for user to add and confirm
If you do not find the person you are looking for, or more precisely, the autocomplete does not suggest the person you are looking for, it is most likely because this person is not part of your team. In this case, this other SeaTable user cannot be added to your group. Only with the help of an invitation link you can share a base with this person and thus collaborate.
Team members with administrator rights also have the option of managing all groups and their members in the team administration. The advantage of the team administration is that you can change the group membership and the respective permissions at the same time.
  2. Click your avatar image in the upper right corner and then click Team administration.
Open the team administration
  1. Switch to the Team area and there to the Groups tab.
Opening the team tab
  1. Find the group whose members you want to edit and click on it row.
Search and select group
  1. In the side menu that opens, switch to the Members tab.
  2. Find the team members you want to add to the group.
  3. Change the role from None to Member or Admin and save your changes.
Selecting team members and adding them to the group
