Do you need a table in your base several times in a slightly modified form? Then you can duplicate it with just a few mouse clicks. It’s that simple:
- In the base header, you will find all the tables in the base displayed as tabs at the top left.
- Click on the drop-down icon next to the name of the table you wish to duplicate.
- Click on Duplicate table.
- Decide whether the table should be duplicated empty or with entries by activating the slider.
- Confirm with Submit.
This is what the result looks like with duplicated entries
This option is useful if you want to transfer at least some of the rows from the original table.
This is what the result looks like without duplicated entries
This option is useful if you only want to adopt the structure of the original table, but want to fill it with other entries. This can happen, for example, if you create one table per year for your budget planning .
