The status-row is located at the bottom of your tables and basically fulfills two different functions, which are explained in more detail in this article:
- Function 1: Counting the rows in a view
 - Function 2: Specify a value calculated from all entries (e.g. sum, average, etc.) for number-based columns.
Thanks to the status-row you always have these statistical basic values in view as soon as you have opened a table.
The status-row indicates at the lower left margin the number of all rows that are in the currently opened table view. If you filter in a view , the status-row counts only the remaining table entries.
In addition, you can select row refers only to the selected entries.
Specification of a value calculated from all entries
For number-based columns, the status-row for each column gives a value calculated from all entries.
Calculation options
For number-based columns, the following calculation options are available in the status-row :
- Calculation of the sum of all entries of the column
 - Calculation of the average value from all entries of the column
 - Calculation of the median from all entries of the column
 - Determination of the maximum value from all entries of the column
 - Determination of the minimum value from all entries of the column
 - No calculation
Compatible column types and formats
For the following column types, the statusrow reflects a calculated value:
- Number columns
- Number
 - Percent
 - Currency
 - Duration columns
 - Rating columns
 - Numerical values in formula columns
For the following column types, the status-row does not reflect a calculated value, although they (may) contain numbers:
- Date columns
 - Created time and Last modified time
 - Automatic number
 - Numbers in text columns
