The Rating column allows you to grade your records in order to rank them or give them a quality score. When creating the column, you can make specific settings concerning the appearance and the maximum number of rating symbols allowed.
Example table with a rating scale
  1. Select Rating as the column type and give the new column a name.
    Give the rating column a name.
  2. Set a rating symbol.
    Setting a rating symbol
  3. Determine the maximum number of points from 1 to 10.
    Determine the maximum rating
  4. You can set a default value that appears automatically in every new row. If you do not activate the slider, the default score is 0.
    Set default value in a rating column
  5. Confirm with Submit.
When you click on a cell in a rating column, the maximum possible number of symbols is displayed in pale gray. To make a rating on the rating scale, simply click on the rating icon that marks the desired score. To adjust an existing rating, proceed identically.
Create and modify a rating
To delete a rating already made in a row, either click on the current value or select the cell and press the Backspace or Delete key on your keyboard.
