You can use the date column to enter times and dates in your tables down to the minute. Simply use the displayed calendar or your keyboard to enter a date manually. Please note that SeaTable does not accept any other data inputs in a date column.
When creating a date column, you can first select a suitable format depending on the region and standard.
Date format selection
In addition, you can decide whether you want to raise the date to the minute or just the day. To do this, activate the slider:
Options when creating a date column
The second slider allows you to set whether a default value (for example, a specific date or the current date) should already be entered whenever you create a new row .
Set a default value in a date column
Confirm the dialog to create the date column. Afterwards you can select any date from the displayed calendar in each row or enter it via your keyboard.
The input of any date is possible via the displayed calendar as well as via the keyboard.
Data collected: accurate to the minute
Collected data to the minute
Data collected: day only
Collected data, exclusively to the day
