With the help of an image column you can upload, save and manage new images in your tables with just a few clicks.
Create an image column
  1. Click the [+] symbol to the right of the last column in your table.
  2. Give the column a name in the upper field.
  3. Select the Image column type from the drop-down menu.
  4. Confirm with Submit.
In an image column, you have several options for adding images. Here’s how:
First double-click in any row of an image column or click on the blue arrow
  1. Click in the cell of an image column.
  2. Click on the plus icon that appears.
  3. A new window will open. Here you can upload images from your device, embed them via URL or add them from the file manager .
In the Local Images section you can click in the field with the Add Documents icon, select one or more image files on your device and upload them to the Image column.
The “Local Images” area of an image column
In the Image Link section you can add images to the image column by entering the image URL. To do this, paste the URL into the empty field and click the link icon .
Add images to an image column using the image address
In the Recently uploaded section, you have access to the file management of the base. Images that you have already uploaded to image or file columns or to your own folders are saved there. Select an image and insert it into the image column by clicking Submit.
The “Last Uploaded” area of an image column
You can also insert images directly into a table. To do this, select any number of images on your device and drag them into the cell of an image column while holding down the mouse button.
Drag and drop multiple images from a device into an image column
As soon as you insert an image file into the image column, the uploaded image is displayed as a reduced thumb nail. You can enlarge this thumbnail by double-clicking on the displayed image.
Preview image files
In full screen mode, you can zoom in and out of the images using the magnifying glasses and switch between multiple images in a row or column using the arrows. You can also delete or download the displayed image file using the and icons.
In addition to uploading images, you also have various options for managing your images in an image column.
You can download images stored in an image column with just a few clicks. To do this, first double-click in a cell that already contains images or on the blue double arrow icon.
Then select the desired image and click on the download icon in the image.
Download images from an image column
If you want to download all images in a column, open the drop-down menu above the column header and select Download all.
Download all images in one column
You can then specify your own file name and the number of files contained in the export will be displayed.
Dialog box to download all files
If you click on the three dots, you have two options for saving the file: A download will save a zip file on your device from which you can extract all the images. You can also save the images in Seafile. To do this, you must first connect a Seafile library to your base .
You can also delete all images that are stored in an image column. To do this, first double-click in a cell that already contains images or on the blue double arrow symbol.
Then select the desired image and click on the icon. Confirm the process by clicking Delete.
Confirmation of deletion
