After 30 days, deleted bases are automatically removed from the system. However, you can also permanently delete the bases manually by emptying the trash in the team administration.
Empty the trash
  1. Click your avatar image in the upper right corner.
  2. Select Team administration from the drop-down menu.
  3. Go to bases on the left side under Navigation.
  4. Click the Trash category under the heading.
  5. Scroll down and click Delete all bases in trash permanently.
