As a team administrator, you can completely delete your team with all its members, bases and data.
To delete your entire team
Switch to the team administration.
Click the Subscription option on the left side under Navigation.
Select the Delete Team tab.
Confirm the deletion.
What happens when you delete your team?
By confirming the deletion, you immediately trigger the following actions:
- Your team with all its team members will be deleted.
- All bases and data contained in them will be deleted.
- Your subscription, if you have one, will be deleted.
- Your data will be removed from our payment system Stripe as much as possible. However, if invoices have been generated, Stripe may not delete your account completely.
- Your email addresses will be removed from our Brevo email system.
Cancel subscription and keep the team
If you cancel your subscription but would like to keep the created team, you can return to a Free account. Read the article Cancel the subscription to find out how to do it.
