As is common in Europe and many other regions, SeaTable uses Monday as the first day of the week by default. However, depending on which country you live in, Saturday or Sunday may be the first day of the week. You can therefore adapt SeaTable to your regional circumstances: In the Date settings, the first day of the week can be set individually for each base.
Change the first day of the week in a base
- Open the base whose date settings you want to edit.
- Click on the three dots in the base header.
- Go to Settings and then to Date settings.
- In the new window, select which day of the week should be the first day of the week.
- Then close the window. The settings you have made are automatically saved.
Scope of the date settings
An adjustment in the date settings causes the selected day to move to the first column in the calendar control of date columns . This applies to the currently open base and all apps based on it.
In the Calendar plugin and on [Calendar pages in apps]/help/kalenderseiten-in-universellen-apps/), however, you can still configure the first day of the week individually and independently of the setting in the base.
