You can perform various operations using the data processing function. You can perform mathematical calculations across all values in a column, as well as correlate values when entries in two different tables are identical.
You can edit already created data processing operations at any time using the view options in your tables:
- Open any table where you want to edit a data processing operation.
- Click on the three dots in the view options.
- Click on Data Processing.
- Hover the mouse over an applied data processing operation and click the pencil icon.
- Make the desired adjustments to the operation.
- Click Save to save your changes or, alternatively, Execute to run the edited operation directly.
