Using the data processing function, you can perform various operations over a column. One operation is the calculation of percentages, which allows you to calculate the percentage of a value to the sum of all values in a column. To do this, simply define a corresponding data processing operation via the view options of your table.
Create a data processing action
  1. Open any table and click the three dots in the view options.
  2. Click Data Processing, and then click Add Data Processing Operation.
  3. Give the operation a name and select Calculate percentage.
Naming the data processing action and selecting the operation type
  1. Define table, view, source column and result column.
Definition of table, view, source column and result column of the operation.
  1. Click Save to save the action and execute it later, or Execute to execute the action directly.
On the first successful execution, a small Green hook.
If the data processing action is successfully executed for the first time, a green tick appears
A concrete use case for this data processing operation could occur, for example, if you collect the number of daily accesses to a website and want to find out what share the access number of one day has of the total number of accesses over all days. For this purpose, you want to calculate the percentage of daily access numbers in another column.
For the implementation you first need a table in which the different days are collected in a date column and the access numbers to the website in a number column .
Example table for the Calculate percentage use case
Then add a second number column to the table, in which the percentage values will be calculated after the data processing operation has been executed. The new, initially empty Percentage Visitors column acts as the result column in the data processing operation, while the Unique Visitors column is the source column.
Adding a second number column
To create the data processing operation, follow the steps described above. Next, define the currently opened table and view. Also select the Unique Visitors column as the source column and the Percentage Visitors column as the result column.
Each time the data processing operation is executed, the calculated percentages are written to the results column. You can execute a saved operation again at any time via the data processing window. Existing values in the result column will be overwritten if necessary.
Result column after execution of the data processing action
Values in the result column after adjusting the format settings
