In the following article you will find instructions on how to import data from Google Sheets into SeaTable.
Data import from Google Sheets into SeaTable
To be able to import files from Google Sheets into SeaTable, first save them as CSV- or Excel file.
Afterwards you can import the files into SeaTable as usual.
Detailed instructions for importing the files can be found in the respective overview article on Excel import or CSV import .
