SeaTable allows you to delete files and images in several ways. The following instructions apply to both image and file columns .
How to remove attachments via the row details.
  1. Open the detailed view of a row, by clicking on the double arrow icon, which appears as soon as you move the mouse over the numbering of the row .
  2. In the row details window, hover over the image or file you want to delete.
  3. In the upper right corner of the miniature, a will now appear. Click on this.
  4. A dialog opens with the question Do you really want to delete this file/image? If yes, click Delete.
Delete files via the cell.
  1. Open the All Images or All Files window by double-clicking the cell in an image or file column.
  2. For images, deleting works the same as using the row details. For files you have the following options:
    • Click Select and select all the files you want to delete. Confirm with Delete.
    • Hover the mouse cursor over a file and click the three-dot icon to select the Delete option.
Delete attachments.
