Available with Enterprise
To be able to make adjustments to already created automations at any time, you have the possibility to manage and edit your created automation rules.
  1. Open a table in which you have already created an automation.
  2. Click in the base header and then click Automation Rules.
  3. Hover the mouse cursor over the corresponding automation rule and click the pencil icon .
  4. Make the desired adjustments to the automation.
  5. Confirm with Submit.
You can adjust the following settings for an automation:
  • The name
  • The table in which the automation acts
  • The view in which the automation acts
  • The trigger event of an automation
  • The columns that SeaTable monitors with a view to the occurrence of the trigger event
  • The filter conditions of the trigger event
  • Add, customize or delete automated actions
