To make it easier for you to keep track of your bases in SeaTable, you have the option to assign a color and an icon to a base when you create it. Both color and icon can be changed afterwards. Here you can learn how to customize the appearance of a base:
Customize the appearance of a base (icon and color)
  2. Move the mouse over the base whose appearance you want to customize.
  3. To edit, click the pencil icon in the right pane, which is just to the left of the three dots.
  4. Select a new color and icon for the corresponding base.
  5. Confirm the changes by pressing the Enter key.
