You have built a sophisticated app that you want to use in a similar way for another user group? Then simply copy the existing app and customize the copy as you see fit.
Copy an app
- Open the base where you want to copy an existing app.
- Click Apps in the base header.
- Hover your mouse over the app and click the copy icon that appears .
- The copy of the app opens in edit mode, where you can adjust the settings directly.
