In each table, you have the option of permanently displaying all available views in a navigation bar on the left-hand side. This is particularly useful if you often switch between views and quick access makes this more efficient.
Pinned view navigation remains visible even if you scroll to the right within a table. This allows you to easily compare entries in different views.
  1. Click on the drop-down icon next to the currently open view.
  2. Click on the pin .
Pinning the different views of a table
As long as the pin is highlighted in red, the available table views are pinned to the left-hand side of the page. To hide the view navigation again, click on the pin again.
