In addition to changing the order, you can also arrange your views more clearly using folders. To do this, create as many view folders as you like and sort your views.
  1. Click the name of the current view.
  2. Select the lowest option labeled View or Add Folder.
  3. Select the Add folder option.
  4. Name the folder and confirm with Submit.
  5. Move the mouse to the view you want to move to the created folder.
  6. Hold the Six dots icon
    Icon for moving elements
    to move and drag the view to the desired folder.
Group views in folders
After you create the first new views folder, all the views you have already created will automatically be in the More Views folder. Move the views to fill your specially created folders.
