A web form converts your table into a form with open fields. A column in your table corresponds to a field in the associated web form.
The classic web form is ideal for online surveys and structured collection of new data, as you can guide users through the completion process.
For access, create a link that allows users without a SeaTable user account to enter data in the web form.
You can learn more about web forms in the linked article.
To create a web form
Open the form management via the web forms button at the top right of the base header.
Select Create web form in the new window at the bottom and click on Classic form.
Give the form a name and confirm with Submit.
The first time you do this, the web form editor opens automatically. The next time, click on the pencil icon to the right of the form name to open the editor.
On the right side, you have a few options to customize the settings, content, and appearance of the web form. Drag and drop the table fields into your design or click the plus icon to the right of the column name to include them in the form.
Click on the Web form page button in the top right-hand corner to display a preview.
Click on the Share button at the top right to create links that you can send to the users of the form.
