If you are still undecided about the design of your base or just looking for new inspiration, SeaTable gives you the possibility to quickly and easily create a base from a template.
Create a base from a Template
  2. Depending on whether you want to create a base under My bases or in one of your groups, click Add a base or folder in the corresponding area.
  3. In the drop-down menu that opens, click Create base from Template.
  4. Select any template for your base and click Use Template.
  5. The base will now appear in the corresponding area on the home page and you can immediately start working in this base.
On SeaTable’s website in the Templates section you will find a variety of templates for different use cases. Each template offers you a preview of the table structure on the website, so you can quickly get a feel for how the base is built.
If you like a template and want to try it out, you can click Use Template to copy the template directly to your SeaTable Cloud in the My bases area. You will also jump directly into the base and can immediately start exploring it.
Templates from seatable.io
If you are not currently logged in, you will first land on the login page. Once you have authenticated yourself, you will need to click the Use template link again.
