You can undo actions in SeaTable in two different ways. SeaTable supports both the well-known key combination CTRL +Z as well as a corresponding option by mouse click. Here you will learn how to undo your last work steps and entries:
If you are currently editing a base or table and you want to undo one or more entries, just press the key combination CTRL +Z to press. Each time you type this key combination, SeaTable will undo your last change.
Alternatively, you can undo your last action with a mouse click in SeaTable’s web interface.
  1. In the top right corner of the base header, click Versions and in the drop-down menu that opens, click Undo.
  2. With each click you undo your last change.
How long can you undo changes?
In principle, you can undo any entry or change within a session. However, as soon as you leave the base, the last work steps can no longer be undone with the two described options the next time the base is called.
What can all be undone?
The following actions can be undone:
  • Inputs/changes in a cell
  • Changes to the columns (name, type, position)
  • Sequence of rows
Actions that cannot be undone
Some operations cannot be undone. These include, but are not limited to:
  • Locking rows
  • Changes to sorting, grouping or filters
  • Comments
