The AI function Classify analyzes the content of one or more columns and assigns each entry to a category. The result is written to a single-select or multi-select column. This way, you can automatically classify incoming texts without having to read each entry manually.
  • Support tickets: Automatically classify requests as “Technical”, “Billing”, “General” or “Feature Request”.
  • Feedback and reviews: Categorize customer feedback by sentiment (positive, neutral, negative).
  • Email inbox: Sort incoming messages by topic or urgency.
  • Job applications: Classify cover letters by field of expertise or experience level.
  • A table with at least one text column that serves as input.
  • A single-select column or multi-select column for the result.
Before you set up the automation, create all desired categories as options in the single-select column (or multi-select column). For example: “Technical”, “Billing”, “General”, “Feature Request”.
Single-select column with configured categories
Create a new automation rule as described in the article Set up an AI automation . A typical trigger is When a row is added, so that each new entry is classified immediately.
Click Add action and select Call AI.
In the action settings, choose:
  • Table: The table in which the AI should work.
  • Function: Classify
Action options for the Classify function
Select one or more columns whose content the AI should analyze to determine the category. The AI reads the texts from these columns and decides based on the content which category fits best.
In the prompt field, you can give the AI additional instructions on how it should classify. This is especially helpful when the category names alone are not clear enough.
Example prompts:
Prompt Effect
Classify the request based on the main topic. Simple assignment by topic
Choose “Technical” if it involves error messages or malfunctions. Choose “Billing” if it involves payments or invoices. Everything else is “General”. Clear rules for each category
Evaluate the sentiment of the text: positive, neutral or negative. Sentiment analysis
Select the single-select column or multi-select column where the result should be written.
  • Single-select: The AI selects exactly one category.
  • Multi-select: The AI can assign multiple categories simultaneously.
Click Save and test the automation with an entry where the category is obvious. Check whether the AI assigns the expected category.
In your helpdesk, support requests arrive daily via a web form. Each request contains a description of the problem. You want each ticket to be automatically assigned to a category so that your team members can work on the tickets in a filtered view.
Configuration:
  • Trigger: When a row is added
  • Input column: Description
  • Prompt: Classify the support request. Choose “Technical” for errors, crashes and malfunctions. Choose “Billing” for questions about payments, invoices or subscriptions. Choose “Feature Request” for improvement suggestions. Everything else is “General”.
  • Result column: Category (single-select with the options “Technical”, “Billing”, “Feature Request”, “General”)
As soon as a new ticket arrives, the AI automatically assigns it to the appropriate category. Your team members can then filter by category and prioritize their tickets.
  • Keep the number of categories manageable. Five to ten categories usually work well. With too many similar categories, accuracy decreases.
  • Describe each category in the prompt. Especially with ambiguous category names, a brief explanation helps the AI with the assignment.
  • Use a single-select when each entry should be assigned to exactly one category. Use a multi-select only when an entry can actually fall into multiple categories.
  • Review the first results. Adjust the prompt if the AI repeatedly classifies incorrectly.
