You can change the order of rows by dragging and dropping. If you reorder rows , SeaTable automatically adjusts the numberings.
Change the order of rows
  1. Click in the numbering field of the row you want to move and keep the mouse button pressed.
  2. Drag the row to the desired position. A black line shows you where the row will jump to.
  3. Release the mouse button as soon as the black line is at the desired position.
You can also move several rows at the same time. To do this, first select the rows . The article Selecting multiple rows explains how to do this. You can then move the rows in the same way as a single row.
rows Move simultaneously
