You can still adjust the order in which the options of a single-selection column appear afterwards.
Simply arrange options using drag-and-drop
- Click the triangle icon to the right of the name of any single-selection column.
- Go to Edit single selection.
- Drag and drop an option to the desired location. To do this, use the area with the six dots located to the far left of each option’s name.
Sorting and grouping
The order of the options is crucial when sorting or grouping by a single selection column. By arranging the options as you wish, you can design your views flexibly.
