Using this page type, which works in a similar way to the data query app , you can search your data records for specific values across certain fields. The page type is particularly useful for extensive data records such as product catalogs or libraries. A specific use case could be, for example, querying an employee directory.
Query pages in universal apps
If you want to change the settings of a page, click on the corresponding cogwheel symbol in the navigation bar.
Change query page settings
In the page settings, first define the table to be searched.
You can then define preset filters, sorting and hidden columns to limit and organize the data displayed for users. To filter or sort, click on Add filter or Add sorting, select the desired column and condition and confirm with Submit.
Add filter on query pages in Universal Apps
Users can see all the information of the applicable data records in the query results if you do not restrict them. Therefore, decide which data should be visible and show or hide the corresponding columns using the sliders.
Hide columns on query pages in Universal Apps
Query fields are of central importance for this type of page. They allow users to search the selected table columns for specific values and thus find data records. Click on Add field in the page settings to define a query field.
Add fields to query pages
You can then select the desired column and set whether the query field should be required, whether a fuzzy search is possible and whether upper and lower case are taken into account when making entries.
You can add an introductory note to your query page, which can contain explanations on how to fill in the query fields, for example. To do this, simply activate the slider in the page settings and write the note in the text box that appears.
Add reference to query pages of the universal app
To be able to use this function, you must activate the slider in the page settings under Is the query result editable.
Make query result editable
All users with access to the query page can then edit the data records they are looking for.
Edit query results on query pages of the app
  • Carry out a successful data query.
  • Move your mouse to the row numbering of the hit list and click on the double arrow symbol in front of the data record you want to edit.
  • Make the desired changes in the open row details.
  • Click on the x symbol to close the window and save your changes.
At the bottom of the page settings, you can restrict who can see the query page.
Authorization for individual pages of the Universal App
This is the only page authorization you can select here. You cannot add or delete rows in the table via query pages.
However, after a successful data query, app users can click on buttons in the displayed hit list to perform certain actions.
Execute buttons on query pages
One application example is an internal job board: the query page allows you to quickly search for relevant positions. If an interesting position is found, a click on the button in the search results is enough to apply for the position directly.
If you only need the query functionality described above for your application, you can also use the data query app directly instead of a universal app.
