Creating a financial plan made easy
Complex spreadsheets and confusing finance tools cost time and nerves. Simplify your financial planning with SeaTable—the AI-powered no-code platform that combines data management and automation. Create, analyze, and optimize your financial plans efficiently—in a structured, secure, and seamlessly integrated way.
Liquidity planning, profitability forecast, financial analysis
Integrated financial planning in the company
  • Financial and investment plan
    Create plans in days instead of weeks thanks to greater transparency. Always work with up-to-date figures and reliable forecasts.
  • Profitability forecast
    Plan ahead and set up automated notifications to detect deviations from the plan at an early stage–for more reliable and transparent forecasts.
  • Management reports
    Visualize complex financial data in clear analysis dashboards. Create meaningful reports with real-time data.
  • AI-powered automations
    Reduce manual work and errors: Use the integrated AI-supported automations for streamlined workflows and intelligent data processing.
  • Work collaboratively
    Use SeaTable as a dynamic finance tool. Manage processes and tasks and collaborate in real time without losing data.
  • Simply record data
    Enter data easily and reduce your manual effort: Create a user-friendly finance frontend with our no-code App Builder.
SeaTable interface for creating and analyzing a financial plan
Create a financial plan online
Create financial planning with SeaTable
With the AI no-code solution SeaTable, you can use a unified planning tool—from capital requirements and financing plans to financial analyses. Let all relevant data flow together automatically in a single source of truth and create maximum transparency instead of Excel chaos .
Automated data integration for P&L and cash flow forecasts
Create controlling and reports in just a few clicks
User-friendly Excel-like interface
Simple tool integration
GDPR-compliant
Fast implementation without IT thanks to no code
Create financial plan template
Templates to get started with your optimal finance processes
For a quick start, you will find free templates specifically for a financial plan in companies. You can flexibly customize and extend each template to fit your capital requirements and financing plan. Import templates into your SeaTable account with just one click.
Write invoice
SeaTable template for creating and managing invoices
Budget planning
SeaTable budget planning template for income and expenses
Cost-benefit analysis
SeaTable template for cost-benefit analysis of projects
For secure financial data
Set up a financial plan without compromising on data protection
When you use a cloud solution and create your financial plan online, your data needs to be particularly well protected. Data protection and data security are our top priorities. We do not compromise when it comes to protecting your data—and neither should you when creating a financial plan.
  • On-Premises
    You don’t want to store your data in the cloud? SeaTable Server offers the same range of functions.
  • Security settings
    Set up individual access and editing rights and restrict access to sensitive data.
  • Authentication and SSO
    Use two-factor authentication and SSO for even greater data security.
Cloud or self-hosted?
SeaTable offers extensive functions in all price models
SeaTable Cloud project plan template for planning finance-related projects
SeaTable Cloud
Perfect for companies that want to get started quickly and without an extensive IT infrastructure - flexible and scalable.
SeaTable Server action plan template for financial measures
SeaTable Server
For companies that want to retain full control over their data, SeaTable Server offers an on-premises option.
SeaTable Dedicated environment for company-wide finance and planning processes
SeaTable Dedicated
For companies that need the simplicity of the cloud and the flexibility of a self-hosted system.
Optimize your financial planning - with SeaTable
FAQ - Create a financial plan with SeaTable
What sets SeaTable apart from other financial planning tools?
Our “Create Financial Planning” tool is characterized by easy implementation without additional IT effort, seamless integration into your existing systems, absolute GDPR compliance and individual customization options. You can combine reporting, analysis, your profitability forecast , your liquidity planning or your capital requirements and financing plan in a single source of truth. Real-time collaboration in SeaTable helps finance teams work more efficiently and flexibly and plan more accurately. Also suitable for a financial plan in a startup.
Which companies is SeaTable suitable for?
Whether you want to create a financial plan for companies, a financial plan for small businesses or a financial plan for a startup: SeaTable is a suitable tool for companies of any size and complexity. Our pricing models are flexible and scalable, so you only pay for the features you actually need. This makes SeaTable the ideal tool for creating your financial plan online.
How does SeaTable support real-time collaboration?
SeaTable allows your entire team to work together seamlessly. You can set deadlines, assign tasks, automate workflows and control approval processes, making it easy to create your financial plan online. Automatic notifications allow everyone involved to keep track of deadlines and changes. This is just as helpful for a financial plan in a startup as it is in a large company.
Can SeaTable also be used to create an investment plan, for example?
You can map all your finance processes in SeaTable without compromising your requirements. You can create an investment plan in SeaTable just as flexibly and collaboratively as you create financial plans or map your invoice management.
How secure is sensitive financial and company data with SeaTable?
The protection of your data is our top priority. SeaTable Cloud is hosted exclusively on servers of a Swiss provider in Germany and is therefore fully GDPR compliant. When you create a financing plan with AI no-code platform , your data is safe.
Can SeaTable be linked to other systems in the company?
Yes, SeaTable integrates easily with other accounting or payment service provider systems - either via the SeaTable API or automation tools. So you always have the choice: you can create your capital requirements and financing plan or an investment plan in SeaTable and link it to other tools, or use SeaTable for other use cases and processes.
How long does it take to create a financial plan with SeaTable and is there a financial plan template?
It only takes a few minutes to set up your SeaTable account - and that completes the implementation and you’re ready to go. Thanks to the intuitive and user-friendly interface and various finance templates, you will be able to quickly create your first financial plan. If you are already using a financial plan template for Excel, you can simply import it. However, how much time you actually have to invest if you want to create a financial plan depends on various individual factors, so we cannot make a general statement on this.
Can SeaTable also be used free of charge?
Create a financial plan free of charge: If you want to set up a financial plan, SeaTable Free already offers all the functions you need. Depending on the complexity or data volume, however, we recommend taking out a Plus or Enterprise subscription. You will need the latter if you want to create a financing plan or draw up a financial plan and use the automation functions in SeaTable. If you create your financial plan online and your existing SeaTable subscription is no longer sufficient, you can easily change your subscription model at any time.
More informationen
